86 chevy 4x4 with a 700r4 problems, possible swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2011, 01:09 PM
I have an 86 chevy 4x4 with a 700r4 that has problems changing gears and would like to know what to check as well I need to know if a 4L60e form a 93 chevy van can be used in its place. If so what all will I need to do to make this work. Thanks a lot and if I were rich I would just buy a new 700r4
Old 08-29-2011, 11:24 AM
DoubleVision's Avatar
The 4L60E is the fully electronic version of the 700R4, it operates entirely off the vehicles computer. To use this trans in your vehicle you`d have to have a aftermarket computer to operate it, and they are rather expensive.
Old 08-29-2011, 11:55 AM
Is the problem changing gears with shifter or is it actual shifting problems?
Old 08-29-2011, 11:57 AM
I have the same exact truck......give as much info as possible on here.........and these guys will help anyway they can.
Old 08-31-2011, 04:14 AM
shifting
no it doesn't shift with gear shift, except back into low, also is it possible to use this 4l60e and just **** it like a manual transmission?
Old 09-03-2011, 08:10 AM
4l60e question
so this transmission cant be shifted manually without the electronics working off computer. I have computer for the 93 van with the transmission. I was wondering if it is possibe to put it on the 86 truck and what it would entail? I have very little money and I am trying to solve my problem. Thanks in advance for your patience here.
Old 09-03-2011, 02:20 PM
If you are short on cash, STOP looking at the 4L60E as 10sec70 mentions it will be MUCH MORE EXPENSIVE to try and install the computer, and associated wiring, to make the 4L60E work in your vehicle.
Just rebuild the 700.
Do you have over-size tires on this truck?
Old 09-03-2011, 03:38 PM
tires
yes it has 31's on it. I can install computer and wiring myself but cant rebuild a transmission, thus my question.
Old 09-05-2011, 04:11 PM
Since you have over-size tires on the truck-have you changed out the ring & pinion sets in BOTH axles to account for the over-size tires?
It's more than just wiring, and the computer that you have to add. Be prepared to add a Throttle Position Sensor, and a Crank Position Sensor to your existing engine as the computer relies on these sensors to control line pressure, shift points, passing gear, lock-up, and probably 100 other things I'm forgetting. Plus, if the computer you have has VATS, you will need to get into the programming and by-pass that portion of the PCM.
If you have the time, patience, money, and expertise-by all means put the 4L60E in it as they are stronger transmissions (by way of higher line pressure-same internals), fewer add-on's to cause issues-no TV cable, and no governor to stick.
But wait, if you have not matched the ring & pinion sets to the tire size-I'd start there before I worried about a transmission, or computer, or wiring, or anything else.
Old 09-05-2011, 04:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Lets go back to your original post then....
is the 1993 chevy van a 4x4 vehicle built by GM? Perhaps I missed that if posted
IF the 4L60e van trans is a 2 wheel drive unit, the out put shaft needs to be changed to a 4x4 shaft for the 1986 chev truck.
Old 09-13-2011, 06:03 AM
Thanks
I appreciate all the answers recieved here and still havent decided what to do, but just wanted to say thanks for the input.
1988 chevy 2500 rebuilt 700r4 problems 88BIGchevy Transmission - Rearend 2 06-24-2010 08:30 PM
92 chevy 4x4 with 700r4 problems Checy_Guy Transmission - Rearend 4 10-31-2009 09:47 PM
83' chevy 700r4 swap 66novaht Transmission - Rearend 2 12-02-2006 08:24 PM
83 chevy 1/2 ton 700r4 to th350 swap? bmoon Transmission - Rearend 4 04-12-2004 07:26 PM
69 chevy c-10 700r4 swap subman17 Transmission - Rearend 0 01-31-2004 04:07 PM
