86 cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 09:09 PM
86 cutlass
what kind of rear end should i go with, i have a 355 with a cam in the 2000-5500 rpm range and a 2400 stall. i'm confused about the 342 gear and a 308 gear. which is the better gear, or can somebody help choose a better gear
Old 07-05-2007, 09:29 PM
BMM BMM is offline
86...200-r4, or no overdrive?
Old 07-05-2007, 10:09 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The higher the numerical value the lower the rear,
a 3.08 means the drive shaft will turn over 3.08 times
while the wheel will make only one revolution,; so on the
highway the engine will run at say 1,500 rpm the car would
be doing about 70 mph (these figures are out of the air for
an example)
Now with the 3.42 the same rpm 1,500 speed now is 55mph
also with the 3.42es you would be able to light them up easer.
As for recommending a gear ratio there is a more information
needed, what do you want to do with the car, what kind of car is it,
trans. I just noticed it's a cutlass, still need the other stuff.
Good luck,
rich
Old 07-06-2007, 06:04 AM
the trans is a th350, i want to be able to drive the car on the expressway but every now and then make a pass on the strip.
Old 07-06-2007, 06:12 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
IMO, you will be happier with the 3.42's. If you had an OD trans, I would look at a 3.73 at least.
Old 07-06-2007, 09:15 AM
RippinRon's Avatar
I went with a 3.42 gear in my 86 cutlass and It was such an improvement over the 2.73s that were in it. By the time you buy the gears and and have it all installed you may be better looking for complete 8.5" rearend from a turbo buick or 442 cutlass. I put a stock posi in mine and destroyed the spider gears with a mild 350.
Old 07-06-2007, 10:00 AM
Hi,
Well with a th350 I would use a set of 3.55es if I were
on the highway a lot, but if I were just running around town
I would step up to 3.73 or higher (lower). When I drove in
the city (philly,) I ran 4.88es. light to light racing. I also think you should
follow RippinRon's advice about changing to an 8.5".
Take care & Good luck,
rich
Old 07-06-2007, 08:26 PM
ok, if i go to a 342 gear what rpm will i run @ 55-65 mph. i have a pair of 15x7 centerlines but don't what size tires to put on the car. plus i can get a 308 gear drum to drum for $300.
Old 07-08-2007, 06:11 PM
Hi,
My guess would be between 19 & 2500rpm somewhere
in that general neighborhood.
rich
Old 07-11-2007, 07:38 PM
ok
thanks alot, is there a why to determine tire size so i can c where im at with either rear end. i mean what at 65 mph w/342 gear i be @ ? rpm.
Old 07-11-2007, 08:14 PM
Hi,
Go to the link below, scroll down to
Actual speed change from Ring & Pinion gear
change calculator, Then when your finished with
that scroll down further to Tire size calculator.
you should be able to find everything you want
to know here, & then some.
Take care,
rich
www.csgnetwork.com/rgpspeedcalc.html
Buick to Olds cutlass part interchanging ltrapper Engine 8 02-08-2006 11:32 PM
Need advice 350 ponctiac in 86 cutlass cutluse1 Engine 1 07-24-2005 12:40 PM
350 swap onto ECM controlled 86' cutlass WsXs3 Engine 1 03-08-2004 08:56 PM
86 Olds Cutlass Supreme T Tops?? Gundarak Body - Exterior 2 12-07-2003 06:38 PM
86 cutlass suspension 86cut Suspension - Brakes - Steering 0 07-21-2002 09:38 AM
