Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 86 ford bronco
Thread: 86 ford bronco
Old 04-18-2006, 11:05 PM
debodt debodt is offline
86 ford bronco
Ive got an 86 ford bronco II 2.9L and i cant figure out why its hesitating(or missing) under load, Ive replaced the fuel filter and the distributor. the compression on the gage is sitting on the low end of normal, the only other things i can think of are the injectors and the intake gasket.
ne ideas??
i just replaced the distributor coil cause ome of the guys at work know more about fords than i do told me it could be the problem, and nothing has changed.
