Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 86 ford bronco
Thread: 86 ford bronco
Old 04-18-2006, 11:45 PM
scholman scholman is offline
Debodt,
I do not think the problem is injectors because then you would have a miss at idle or under a load. The same would be true if a gasket was leaking too.
My money is on the air intake hose leading to the throttle body. I think if you look, you will find either a hole in the hose or one of the clamps is loose and allowing air to enter the engine unchecked and unmeasured.
Good Luck
Scholman
