86 Ford (lincoln) key switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2011, 02:51 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I am looking for a wire diagram of a 86 Lincoln connector at the key in the column.
This is a 11 pin connector with 2 vacant positions.
I am trying to merry this to a E_Z Wire harness that has GM connectors for the starter acc switch.
The next challenge will be the turn signal switch on this 86 Lincoln column to the E-Zwire!!!
Old 08-22-2011, 12:41 PM
35terraplane's Avatar
Key switch
Did you try a Lincoln dealer, get the color code from them. Gm was pretty much all the same, where ford used colored stripes on theirs and I don't know if the Lincoln and the ford are the same. I have a 87 Turbo Coupe column, Tell me the colors and I will see if they are the same, if they are I could tell you what they are for, Both the key and turn signals.
Bob
Old 08-22-2011, 04:32 PM
solidaxel's Avatar
Thanks,
Here are the colors:
Yellow Vacent
Yellow Black/green stripe&Reistor wire
Vacant Brown/pink stripe
Slate/yellow stripe Red/tan stripe
Slate White/red stripe
Purple/white strip
Name:	56 Ford 015.jpg
ID:	57750   Click image for larger version
Name:	56 Ford 016.jpg
Old 08-22-2011, 07:37 PM
Key switch
Thanks,
Yellow Vacent
Purple/white strip
I will look in the morning but I think my Turbo Coupe has Grey wires with the colored stripes, I will look and see if any are close. I can call a buddy of mine that has a shop and does a lot of wiring, maybe he has something that far back.
BOB
Old 08-23-2011, 07:07 PM
wiring...from memory, major colors as noted:
yellow x 2...battery,
grey/stripe...heater 1,
grey...heater 2.
red/stripe...ignition 1,
brown/stripe...ignition 2,
black/stripe...accessory,
white/stripe...starter,
purple/stripe...bulb check?
mark
Old 08-30-2011, 04:15 PM
solidaxel's Avatar
Thanks for the info on the start-Ing wiring!
Now on to the turn signal switch for this lincoln column
There are 5 wires coming from the plug, I will get the colors tomorrow but one is a Blue and one has a double green attached to the spade, I will see the truck tomorrow for the rest of the wires.
I am trying to merry this column to a EZ wire kit
alternator '34 ford/lincoln mark VIII engine printworksla@mac.com Engine 9 01-01-2008 11:53 PM
Lincoln LSC 5.0 HO into 1966 ford GTA ?? SSuperwrench Engine 7 02-09-2007 04:08 PM
Ford Lincoln Rear Disk brake help TurboS10 Transmission - Rearend 7 10-03-2006 09:09 AM
1995 Lincoln air bags on a 51 ford victoria Awosy666 Suspension - Brakes - Steering 1 11-28-2004 10:56 AM
Ford transmission switch Jim69Mustang Transmission - Rearend 3 10-15-2003 03:35 PM
