Originally Posted by bubbahotep
Happy fathers day. My day has been a fail. lol
86 monte ss, rear upper control arm: I can easily reach the head of the bolt that is on the body side (not the rear end differential) of the control arm and was able to heat the nut of the other side which enabled me some rotation on the bolt with an air gun. However, after hours, I was never able to get the nut to free from the bolt. Totally impossible.
Are there any tools to just cut off the head of the bolt? I have a nut splitter but it cant reach the nut. I tried drilling the head of the bolt but its grade 10 and I think I barely saw a scratch. lol. Heating the nut with a torch is not accurate and seems to heat the bolt so they both sometimes lock together.
Possibly remove the rear springs and grind the head off? Would an air chisel be able to bang off the head of the bolt?
Im not a mechanic and this is all being done in my home garage. A plasma cutter is not happening.
Something
here will work. IIRC those nuts are lock nuts. I'd use PB Blaster after heating, then an impact wrench.
