'86 GMC carb problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2004, 04:17 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i have a '86 GMC 1/2ton w/4.3 V6 and Q'jet carb. i recently bought the truck and decided to rebuild the carb because the truck idled rough and wouldn't start after sitting for a few days.
so i got the carb rebuilt and it starts right up, but now it idles too high and i've got the idle backed right off. the truck is also dieseling now and i'm thinking it's a combination of high idle and timing.
so i guess what i want to know is does anybody know what my timing should be set at and what would cause the engine to idle too high when the throttle plates are closed?
another thing about this carb is that it is a 4bbl but it looks like there is a pin on the secondary plate rod and a cam on the side of the carb that locks out the secondaries. what's up with that?
thanks,
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 10-21-2004, 05:12 PM
Tazz
Sounds like timing is way off and throttle stop out of adjustment!! CK here: www.chevytalk.com/
Tazz
Rat Rods Rule!
Old 10-21-2004, 11:59 PM
sbchevfreak's Avatar
Licenced Automotive Technician
try pushing the secondary throttle closed. they have been known to stick slightly open and cause an unadjustable high idle. That lock out cam, if it is on the choke side of the carb, is there to block the secondaries from opening while the choke is on. (if i'm thinking of the right cam! )
Your dieseling could be caused by carbon buildup on in the engine, and the high idle is keeping it hot, giving you a source of ignition after the key is off.
Old 10-22-2004, 03:29 PM
thanks guys.
sbchevfreak, i think you might be right on the choke cam thing. if i remember right the cam pivots on the same spindle as the choke. just when i looked at it on the bench it didn't look like it would move at all, it looked like it was wedged in there on purpose so the secondaries wouldn't open at all.
we'll see how it goes.
thanks,
JB
