86 Pontiac Trans Am lower from air damn thingy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 12:32 PM
tweed's Avatar
there a part that gone from under my radiator and i dont know how big or small it is.where it was is a bit of hard plastic like material and 6 bolts.the section that has bolts init is about somewhat over 2 ft in length.my car runs hot without it so i think it might be something called alower front air damn.if anyone knows what this is and maybe has pics and knows where i could get this part,i would be soo thankfull.
Old 07-22-2011, 12:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
www.car-part.com your local parts yard..
Sam
Old 07-22-2011, 02:51 PM
tweed's Avatar
Sam
They didnt have an option for a air deflector,if thats what its called.
ill try to post this pic of where the thing goes so maybe someone can tell me what goes there lol.whatever those 6 bolts held on is what i need.
Old 07-22-2011, 04:10 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
Use carpart to find a yard w/ the same bumper as your car and then call said yard about the air deflector. Its to cheap of a part for it to be listed as an option on the site.
I cant recall if the air damns are all the same or if the trans ams had their own design to account for the different bumper. My 84 v6's air damn was just a simple L shaped piece that had a few bolt holes
Old 07-22-2011, 09:20 PM
RippinRon's Avatar
Here is a pic of a custom one but you get the idea. There is also the rest of the plastic that is important. The camaros and firebirds were different due to different nose designs.
Old 07-22-2011, 09:51 PM
tweed's Avatar
thanks for the help everyone.i couldnt find that part anywhere so i got some sheetmetal im going to see if i can work something out but as far as the rest of the plastic stuff goes,i have no idea what it is O_o
Old 07-23-2011, 02:16 AM
I had the same part missing on my old 86 firebird. it ran hot till i replaced it. Its not much but helps air go through the radiator. good luck
Old 07-23-2011, 07:14 AM
DRS50's Avatar
Last journal entry: Epoxy primed the body today
Several listed on ebay
http://motors.shop.ebay.com/items/?f...sop=12&_ipg=50
Or you can try Harks Third Gen Parts
Old 07-23-2011, 08:45 AM
RippinRon's Avatar
It works as a system you need more than just the part that hangs down. It being open underneath just causes turbulence. Check out thirdgen.org
Old 07-23-2011, 12:42 PM
tweed's Avatar
the prob is i dont know what parts go uner there.i went to the ebay link and it shows 2 different ones.one is a 3 piece and the other is a strip with something connected on each side.sorry im a noob.
Old 07-23-2011, 02:21 PM
RippinRon's Avatar
thirdgen.org search it
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 05:14 PM
39 Pontiac Lower A arm pivot question rwruther Suspension - Brakes - Steering 2 06-29-2006 04:58 PM
Oil Filter thingy jrm123180 Engine 4 12-07-2004 09:27 PM
455 pontiac in 84 trans am c.k. the customizer Engine 3 07-07-2003 10:53 PM
Trans cooler = lower engine temp JUSTINH Engine 1 06-06-2003 02:40 PM
