86 s-10 vibration cab mounts bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2004, 07:50 PM
Hello, I have a 1986 s-10 that has vibrations when the engine is worked hard, like at 2 grand and above. sounds like a drill motor is set directly on the cab and run. So I was wondering if bad cab mounts will cause this. My front cab mounts are rotted and the cab is sitting on the frame. I have a new cab for this truck, but havent put it on yet due to weather
Old 01-25-2004, 07:57 PM
86 s-10 frame wearing thin from rust
Hello, i have a 1986 s-10 that the frame is solid, but wearing thin above the rear wheels on the inside of the C frame. From the outside of the frame, it looks normal, but on the inside it looks bubbly and thin. What can I do? Would a body shop fix this or should I fix it myself or just graft on a new rear frame section. Not sure what would be easier. Always wanted to buy a welder, maybe I should buy steel and weld it myself? Welded in high school, but that was 1986...lol. Lookin for some ideas to keep this thing on the road
Old 01-26-2004, 01:20 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
S-10's are a dime a dozen. If yours is in good shape then I would buy another and swap out frames. A weekend job for swapping. And maybe another day or so to prep the new frame.
Kevin
Old 01-26-2004, 01:21 AM
Kevin45's Avatar
Put in new mounts.
Kevin
Old 01-26-2004, 03:23 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Long Bed or Extended Cab? If so, check the carrier bearing.
Lowered? Check the pinion angle.
