86 Suburban - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 05:38 PM
86 Suburban
Hey guys,My old man has a 1986 Chevy suburban with a 350 which recently locked up. so ive got a 327 im gunna put in there and i was wondering if the exhaust manifolds will bolt up to the 327.
Old 10-09-2006, 07:28 PM
DoubleVision's Avatar
yes they`ll bolt up, however, the 327 doesn`t quite have the torque of a 350 to move a heavy suburban, If the 327 is stock, I would add a RV camshaft and a double roller timing set, this would give it more torque so the smaller 327 wouldn`t have to work so hard to get the vehicle moving.
Old 10-09-2006, 08:08 PM
thanks. ya i know it will be short on torque but its just a temporary fix
Old 10-10-2006, 11:16 AM
SBC SBC is offline
Need You A Good 383 In It For The Long Haul.
Old 10-11-2006, 07:14 AM
Thanks for the replies. also i have run into another problem the 327 heads don't have any accessory holes i was wondering if you can drill and tap new holes or will I hit a water jacket or something. or is there something else i can do or am i just outta luck.
Old 10-11-2006, 01:29 PM
SBC SBC is offline
I had a pair once that had been drilled, they worked fine. I didnt drill them but it did work. in one of the heads they did hit water but it worked as long as the bolt was in it.
Hope this helps.
Old 10-11-2006, 04:05 PM
Thanks SBC. Is this something i can do myself or should i have a machine shop do it. Will a regular tap work to cut threads on cast iron
The difference between Pre 86 chevy 350 and post 86 350's haaslyd Engine 12 12-15-2011 08:37 PM
87 Suburban tbi to carb swap, question on tranny Mustangsaly Transmission - Rearend 3 05-26-2006 07:10 PM
Where to find door felts/wipes for '86 442 STATUTORY GRAPE Body - Exterior 18 02-28-2006 10:49 AM
86 suburban computer bigjak Engine 2 02-07-2004 03:02 PM
86 suburban steering troubles fantasy77 Suspension - Brakes - Steering 3 10-28-2003 09:29 PM
