86 trans am rear brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2011, 10:16 AM
ogre's Avatar
the 'Duracell Project'
my 58 pickup has an 86 trans am rearend in it, came with rear disk brakes, posi and 3.27 gear.
the rear disk brakes have an integral parking brake in the piston.
the seal on the parking brake started leaking, even though i don't use it or have it hooked up.
calipers are the same left and right, left in back and right up front.
is there a caliper swap that i can do to, that will give me an easy to hook up parking brake?
maybe even a backing plate, rotor and caliper swap...
Old 06-28-2011, 11:52 AM
Wiki Edits: 27
eldo ?
Rear disc's off a mid 80's caddy eldo might work They are an easy swap on early gm cas.
Old 07-01-2011, 11:12 AM
1971BB427's Avatar
I've also heard that S10 rear disc brakes fit pretty easily.
Old 07-01-2011, 12:58 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
....And are 1000 times better system,
Old 07-01-2011, 05:50 PM
RippinRon's Avatar
If it really has a 3.27 ratio it is a Borg Warner 9-bolt rear (count the cover bolts). The calipers should be cast iron. There are not any aftermarket brackets to change calipers. I've heard that later (1989) 9-bolts sometimes came with pbr calipers that were the same as f-bodies, c4s and c5s.
should i swap trans and rear or wait? Jason7504 Transmission - Rearend 29 01-08-2011 05:31 PM
MK VII Lincoln rear disc brake swap Brian S Suspension - Brakes - Steering 6 05-12-2006 12:21 AM
'79 and '83 Rear Brake swap RONNYinWAXHAW Suspension - Brakes - Steering 1 01-04-2006 06:04 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
rear end swap from a trans am to a chevy malibu bigslickwille Transmission - Rearend 3 12-20-2002 02:34 AM
