86-up sbc timing cover...??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2003, 05:15 PM
nastynova's Avatar
Post 86-up sbc timing cover...???
I was going to buy an edelbrock aluminum two piece timing cover and saw that will not work on 86-up sbc...?...does anybody know why not?...whats different about the 86-up...I don't see this note on other covers, is it just something with the edelbrock cover??
thanks
Nasty
Old 01-19-2003, 05:18 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Probably the timing tab is attached to the cover on 86-newer, not sure though.
Old 01-19-2003, 05:19 PM
Post
1986 up Chevrolet blocks have a different oil pan sealing system, annd a different oil pan seal.....so that the later 86 and up stuff will not fit 55-85 stuff.
:p
Old 01-19-2003, 05:25 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
DOH, I knew that! :o
Old 01-19-2003, 06:20 PM
nastynova's Avatar
Post
I knew the rear of the oil pan was different but didn't think the front was......
Old 01-19-2003, 07:42 PM
Post
1986 and up use a one piece rear crank seal.
Paul
Old 01-20-2003, 04:48 AM
crshrmn3's Avatar
Post
When I built my '86 350, I used a chromed timing cover off an older sbc. The timing tab is located different. My '86 timing cover had the timing tab located in the center and the damper had TDC at 12 o'clock. When I went to the older timing cover, I also had to go to the bolt on timing tab and damper that had TDC at 2 o'clock. The oil pan is different from pre-85 to 86-later, but the timing covers will bolt up. I used a one piece rubber oil pan gasket for '86-later and had no leaks.
