86 vette seat & door lock problem... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 07:36 PM
The Drivers seat, (only one thats power), & the door locks have failed. The Breaker is too hot to handle. Any suggestions? plus i am having a hard time locating the relays...
Old 03-07-2006, 04:48 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That Circuit breaker handles both If I remember right..
Sounds like the seat is "Rotor Locked" , motor or seat jambed in a the tracks where the motor can't overcome the opposing force. you need to pull the seat and inspect the tracks and the motor drive for a locked Condition.
Is this Corvette standard seat? or a Riccarao (SP?) , I don't show a schematic for the seats in that year..Does it have position memory and heat? If so those relays will be found in a box under the seat.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-07-2006, 05:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
To expand on the Doc's post.
You may have a seat or a window switch that is stuck. This will cause the motor to be always trying to run but cannot because it's at the end of it's travel.
The circuit breaker will "trip" OFF due to the high current draw of the stalled motor. When the circuit breaker cools, it will reset ON and again trip OFF as above.
Try to isolate the windows from the seats to rule out which system is causing the problem.
Start by disconnecting the wires at the seat motors. And check to see is the windows work OK. Then reconnect the wires one at a time, noting when the problem occurs. Likewise with the windows.
vicrod
Old 03-07-2006, 05:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Thanks Vicrod!
Doc
Innovations
Old 03-12-2006, 08:36 PM
86 Corvette Seat Problems
Thanks Fellows, I sure appericate your time and effort. The seat is just a factory unit, no memory or heat. It just goes up and down, and forward and reverse...I had a chance to remove the front track nuts, but haven,t had the time to go any further.. Hopefully this week my scheudle will slow down a bit so that i can try to finish the job...Sure want to finish this so that the little woman can enjoy her toy...Thanks AGAIN, And I,m In-the-Weeds...
1994 Saturn Transmision Problem dmg53 Transmission - Rearend 4 01-18-2006 07:59 PM
74 Corvette Brake Problem iniguy Suspension - Brakes - Steering 7 07-02-2005 05:46 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 06:44 AM
350 turbo in vette problem mikeweyman Engine 2 03-26-2003 08:00 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 06:18 PM
