86 Z28 w/ 400 ci NEED HELP
I recently purchased a 1986 Z28 Camaro that has a 400 small block replacing the original 305. The gauges for the oil,speedo, and temp guage aren't functioning. which i realize is because the 400 sb doesn't have the ECU comp like the stock 305. So what i am wondering is there a way to hook up any of these gauges or? I also need any information about the 400 sb.
Thanks Aaron |
1. welcome to the forums.
2. I usually post this link to an introductory video, which is funny so here it is http://www.starterupsteve.com/swf/posting.html /\that video is brought to you by the United States Health and Human Services Department 3. Be more specific on what you want to know about the 400ci Chevrolet. |
The gauges are not connected to the ECM. Each has its own sensor on the engine. Get a good wiring schematic. The oil and temp have different sending units depending on whether they're idiot light or gauge. As far as I know, the speedometer is connected via cable, just like the old ones.
correct. The gauges in that car are all connected to the individual sensors on the engine. The person who did the swap just got lazy and didn't hook them up
![]() I agree, just get a wiring diagram and hook them up. |
It has the original 700r-4 Tranny in it. I'm thinking of just replaing the 400 sb with a 350. The 400 runs decent, but it needs alot of bottom end work. Any other suggestions on other engines beside a 350 to replace the 400? I'd like to keep it a small block seeing as how it already has mounts and headers for a small block. I'd like something that has a nice mellow rumble with a roar when it's accelerating. Which by the way my car does have true duals with thrush glass packs (came with the car when I bought it) any opinions on exhaust mufflers/packs would be appreciated.
I'm running a 350 with edelbrock intake and rochester carb. Combine that with hedman headers and a mid range cam(485-286)lift and duration, and you will have a nice lope and rumble to your engine../mkf
My $.02...fix the 400. You won't find another small block that has the same torque without spending a lot of $$$.
I have a 406, 200R4, with 3.42 gears in my '86 El Camino. Great combination. |
| Mid 70's 400 ci. Junk or not??? | 70bird | Engine | 26 | 12-18-2005 10:37 AM |
| chevy heads desireable for the rebuild of a 400 for my 3/4 ton 86 2x4. | nh32u | Introduce Yourself | 4 | 12-17-2005 06:31 PM |
| 400 CI lack of power | 77chevy400 | Engine | 6 | 12-16-2005 11:15 PM |
| 86 Z28 | 86z28 | Introduce Yourself | 4 | 12-16-2005 01:50 PM |
| 400 pontiac into 86 camaro | MN'maro | Engine | 6 | 10-17-2003 09:12 AM |
