We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 11-20-2008, 05:27 PM
Dmaleck Dmaleck is offline
87 14 bolt Question
Will 14bolt 13" Brake drums off a 88 1ton Duelly, fit an 87 single tire 14bolt? Thanks in advance!
Old 11-20-2008, 06:09 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
I dont think that will work for you, The DRW & SRW housing's are different. The backing plate mounting flange on a DRW is set farther in on the housing to be able to take the big offset of the drum. The brgs and seal are the same but the only way that might work is to move the backing plate flange to the correct position.
Old 11-23-2008, 12:40 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
curtis73's barnstar
Wiki editor
Wiki Edits: 16
No they won't. SRW axles had a completely different setup.
Here is a SRW drum followed by a DRW drum. Notice the "hat" is much taller on the DRW. That is to compensate for the offset of the dually wheels and so that they are centered further out.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "87 14 bolt Question"
dodge 14 bolt cowtipper Transmission - Rearend 4 11-13-2008 08:16 AM
How hard is it to swap in a 14 bolt? Ford_Assassin Transmission - Rearend 2 10-23-2008 05:41 PM
12 bolt 3.73 question Chevy21 Transmission - Rearend 8 02-14-2008 01:45 AM
12 bolt or 14 bolt? steveyb4342 Transmission - Rearend 10 10-03-2007 05:17 AM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
