87 3/4ton Dual Stabilizers HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2008, 09:36 PM
I have this set http://images.google.com/imgres?imgu...n%26safe%3Doff
The problem is I bought an axle and got these with it, Iv never seen these installed on a truck before and I dont know how they bolt on. Has anybody installed these? or does anyone have any good pics of it on? The kit will be going on a Corp 10 bolt . Thanks!
Old 12-29-2008, 10:23 PM
Joe G's Avatar
Registered user
http://www.tuffcountry.com/NewFiles/66250.pdf
Here is an installation manual for a similar kit.
They show it being installed on a Super Duty, but it may answer some of your questions.
I checked the Tuff Country website, and instructions for your exact kit are not available online. However it says they will fax or mail them to you upon request.
Hope this helps.
Joe G.
Old 12-29-2008, 10:31 PM
hevy chevy's Avatar
I Got A Good Pic
My Budys Truck
Old 12-29-2008, 10:33 PM
Cant seem to get that 1st link to work...not much of a computer guy Thanks for the help though!
hevy chevy....wheres the pic?
Old 12-29-2008, 10:43 PM
Joe G's Avatar
Registered user
Here's a pic from the instructions I tried to link to:
Old 12-29-2008, 10:46 PM
hevy chevy's Avatar
Not Much Of Computer Guy Ether
I Will Keep Tryin
Old 12-29-2008, 10:50 PM
hevy chevy's Avatar
I WILL KEEP TRYIN
Old 12-29-2008, 11:00 PM
Hevy I think the brackets I have are for the inline style Stabilizers not the parallel setup like your friends. Still cant see much from that pic though Joe G
Old 12-29-2008, 11:13 PM
hevy chevy's Avatar
question
Did U Look On U Tube. I Watched A Video On How To Install A Trailer Hitch Om My Impala
Old 12-29-2008, 11:14 PM
Joe G's Avatar
Registered user
Originally Posted by Dmaleck
....Still cant see much from that pic though....
Old 12-29-2008, 11:22 PM
hevy chevy's Avatar
That Is The One
Looks Farley Simple No
Old 12-30-2008, 12:05 AM
Joe G's Avatar
Registered user
I agree.
It looks like you just center the axle bracket in the middle of the truck, and position the outer mounts so the shocks can neither bottom-out nor top-out before the end of the steering travel in either direction.
But that's an assumption, I hate to assume...
I'd call the manufacturer just in case there are some critical dimensions or angles you might need to be concerned with. Their website encourages calls regarding installation questions. The number is (800) 288-2190.
Good Luck
Joe G.
Old 12-30-2008, 08:55 PM
Thanks for the help guys, I'll probably just end up calling them another day because its a little differnt setup then that other truck. Thanks again!
Old 12-30-2008, 09:23 PM
hevy chevy's Avatar
THX for chating
HOPE IT WORKS OUT FOR U BUD . LET ME KNOW HOW IT GOS KEEP IN TOUCH
454 tbi or dual tbi on dual 4bbl carb intake 90GMCVortec Engine 3 10-28-2008 02:48 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
700R4 fitting post 87 drum to pre 87 box eliotmansfield Transmission - Rearend 4 05-10-2005 08:02 AM
Dual Quad setup chevyIIdie4 Engine 8 06-23-2003 09:31 AM
Single plane and duel plane manifold stonedchihuahua Engine 21 01-06-2003 11:56 PM
