87 350 one piece seal flywheel 153 or 168 tooth - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2005, 08:12 PM
im trying to fig out what flywheel i have cuz im looking for a high torgue starter and im not sure what i have. any help would be great.
Thanks!
Old 08-03-2005, 08:26 PM
If you can measure the diameter of the flexplate/fly wheel you can determine your tooth count. A 14" diameter plate will be 168 toophasiz. 12-3/4" will be 153 toophs.
Old 08-03-2005, 08:46 PM
302 Z28's Avatar
I just bought a Powemaster Ultra Torque starter for my crate Fastburn 350. I believe the model number is 9400 it will fit either a 153 or 168 tooth flwheel and it is a real brute. I did have one of the mini Delco knockoff's and didn't like the way the bendix was slow about disengaging after the engine started, it sounded terrible. This starter is awesome, it spins the Fstburn over about twice as fast as the Delco knockoff, and the bendix disengages when it's supposed to. It has a machined aluminum mounting plate with three different clock positions for the starter. It also came with a set of the proper bolts.
Vince
Old 08-03-2005, 09:13 PM
lluciano77's Avatar
Count the teeth next time
Old 08-03-2005, 10:54 PM
IROC_385z's Avatar
Someday it will work right...
What car is it out of? Is it a flywheel, or a flexplate? The late 80s/early 90s fbodys usually have 153-tooth flexplates, if that is any help.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Flexplate 350 Chevy 153 or 168 tooth? Ghetto Jet Engine 5 05-18-2006 09:45 PM
rear seal leak on sbc 350 4onthefloor 2 Engine 9 03-23-2005 03:04 PM
350 rear main seal??? Brian Morency Engine 9 06-09-2004 06:12 PM
rear main seal in 350 bstm23 Engine 4 12-02-2003 12:57 PM
