#1
87 5.7 Tbi
Can anyone tell me if an older carb 5.7 block and be used on a 87 5.7 TBI using the heads and intake from the TBI engine?
Register now (free) or login to remove ads |
#3
Yes, but you'll need the older engine's flywheel or flexplate to bolt to your clutch or torque converter as the older engine will have the 2 piece seal crankshaft which uses a different bolt pattern on the flange from that of one piece seal blocks. Bogie |
#5
Follow FastOrange's comment, I forgot to mention that if the cam is different the TBI will not track correctly to mixture and advance. It's really sensitive to this. Bogie |
