'87 bird rearend swap to 9" - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2002, 01:48 PM
New Member
Post '87 bird rearend swap to 9"
Is there anyplace that specializes in making bolt in 9"ers for applications like this? And is there a good setup available for mounting so I don't have to use that goofy torque bar between the trans and rearend? The car will see street and strip and I don't think the factory setup will handle the abuse I plan on putting this through?
Old 04-16-2002, 06:29 PM
New Member
Post
www.moserengineering.com makes some 9" housings for some $$$, but with a kit that should bolt in. ted
86 Monte Carlo SS ttops
cleaning it up for the big block and 8.5 rear
Old 04-17-2002, 02:39 AM
aka Duke of URL
Arrow
-Currie Enterprises- makes what you want.
Old 04-17-2002, 08:01 AM
New Member
Post
Thanks guys, both of those site have everything I need.
