87' Bronco 2 4x4 One touch 4x4 button - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 10:26 AM
New Member
Unhappy 87' Bronco 2 4x4 One touch 4x4 button
Hi Everyone,
I have an 87 Bronco 2. The 4x4 worked fine until all of a sudden. The over head console that houses the "OneTouch Shift" buttons use to click and lightn up when I engaged the 4x4. Now I get nothing...no indicator lights or clicking when I press the buttons. The 4 wheel drive does not engage at all, like as if it has no power going to it ...I checked the fuse panel and the fuse seems fine. I took out the Electronic module which is under the dash near the passenger side dash speaker and it has a red light on it....Any suggestions?
How can I get then 4x4 to work again?
Old 02-08-2003, 03:49 PM
Post
is the red light lit up on the relaybox and have u tryed to press the reset button on it?
in my opinion if the relay box led lights up when u press the reset button, its not the relay box
based on my experience with symptoms as i described it would be the pcb inside of the actuator mounted on the transfer case
