Thread Tools Search this Thread share on Facebook
  #1
Old 09-15-2003, 03:24 PM
Dans83Olds's Avatar
Dans83Olds Dans83Olds is offline
Sucking Gas & Haulin' A$$
87 camaro 700r4 problems
I installed a shift kit and a trans-cooler in my 700r4 when I replaced the engine. I am now having problems with the transmission. If i shove it in 1st and punch it it will not hold first. It will automatilly shift into second. When it shifts to second it under power it will act like its sliping. Under light acceration all the gears shift fine. We have tried to adjust the tv cable severl times but to no avail. If the transmission on its way out?
Register now (free) or login to remove ads
Old 09-03-2005, 09:31 AM
nannie nannie is offline
Shifting Problems
Have you tried replacing the Detent cable that comes from the throttle body? IF not the cable its self could be bad. THat cable controls the whole tranny and if it is messed up everything doesn't work right. Hope this helps.
Old 09-03-2005, 01:16 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1,659
Depending on the year of your 700 tranny, they will upshift to 2nd while the shifter is in first.... pre 1987 700 trannys do this.
A larger low/reverse boost ( .296 diameter) valve will delay the up shift.
Slippaged in 2nd gear is the band slipping. THe band could be burned up , a small servo is in your tranny ..
Old 03-13-2006, 05:16 PM
85IROC 85IROC is offline
700-r4
It Souds Like A Typical Problem most Said The 700-R4 Wasn't A Good Trans Try Checking The Actuator Spings Located To The Passenger Side Of The Trans They Were Notorious For Breaking. If You Put A Shift Kit In It Depending On How You Set It Up, Street/Strip You Remove The Springs And Put Spacers In Place (Solid) Setup. For Heavy Duty Towing You Reuse The Springs, The Springs Do Have An Effect On Shifting. Also Try Replacing The Servos On The Passenger Side Of The Trans They Put Alot More Pressure On The Bands Than The Stockers Holding It With Greater Force. If That Does Not Fix It You Might Want To Look Into A Rebuilding Kit.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
