87 Camaro 700R4 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2003, 12:11 AM
Dans83Olds's Avatar
Sucking Gas & Haulin' *****
Question 87 Camaro 700R4 Question
I have an 87 camaro with the 700R4. I was wondering how to bypass the electrnics for the tranny to install a hopped up carbed 350? Also what do I have to do to make the tranny handle 400hp? Thanks
[ May 03, 2003: Message edited by: Dans83Olds ]</p>
Old 05-03-2003, 12:36 AM
Post
There are stand alone computers for using the 700r4 in pre computer cars. just get one of those and you will be all set. I believe they are under a $100
Old 05-03-2003, 07:42 AM
Post
Just find a computer controlled carb,you might need to rob the chip too but,the tranny will still work anyway,the only exterior conection to the motor is the throttle cable that controls shifting.My s-15 has a carburerated engine and it has a th350 with the computer plugged into it and I've experienced no trouble with it at all.Now,to handle more horse power you would defenitly need to install a shift kit in one of those.The problem with the 700r was that they are not designed to handle much more than stock power,and the fliud return holes for overdrive are too small.The end result is a cooked tranny.You might want to fix that as well,or you could just aviod overdrive untill you hit 45-50 MPH.And a tranny cooler is a must for those trannys.I finally broke down and had a 700r built for my truck(after 3 of them).After all said and done,the 200r would have been a better choice because they will handle more power with out any work and they don't need a computer.
Foot to the floor,hair back,knuckles white.
Old 05-03-2003, 12:15 PM
bluesman123's Avatar
Red face
I thought the 700R4 was the pre-computer version of the overdrive unit and the 4L60E was the post-computer version of the same tranny. The only computer link I have on my old 700R4 is/was the VSS wire to the DRAC, and the torque converter lockup lead.
Doesn't the 700R4 still use hydrolic shifters?
I am SO CONFUSED!!!
Old 05-06-2003, 07:01 PM
Bartman39's Avatar
Post
bluesman123 you are correct the 700R4 is not an electronic shift transmission... It uses a detent cable for downshifts and uses pressure and valving to shift not the soleniods and electrical sensors as the 4L60E or 80E also... Infact the 87 and older 700R4`s (I think...?) can be modded to do lockup without the electrical part as well... The newer (around 88 and up) might also be done this way but not for sure on that one...?
Old 05-06-2003, 08:21 PM
Post
The 700r4 is not an electronic controlled trans. But, the lockup converter sure is. Summit has kits from TCI and Painless that let you lock up the converter.
Old 05-07-2003, 09:39 AM
EBlack36's Avatar
Rebuilt Excitment
Post
You can also run a hot wire to the plug and to a switch and lock it up manually, I have also read of running it through the brake light switch.
