Glenn, thanks a lot. I didn't really understand. But All I have to do is properly ground the tank... That sounds easy enough to check. Does the pump have its own ground or am I just lucky that it still works...assuming that the ground is the problem? Thanks again, John
i had a similar problem with an 88 version of that car. all i did was replace the gauge. all of those 3rd gen camaros have those gauges. get one from a wrecking yard and it might save you lots of work. the dash is much easier to take apart than the tank. just use a torx wrench and the gauge just pops out with a flat head screwdriver.
maybe its not broken, maybe you get very good gas milage, llolol!!1
Chevyman...that is actually pretty funny. I told the guys at work that I must be getting super gas milage because my cars been on FULL for 2 weeks. They laughed and then someone said, just use the speedometer/milage. They really got a laugh when I said that broke a week before the gas gauge. I'm pretty sure that the speedo is a bad cable. Its real hard to turn. This thing is just at that age where you either going to rebuild it, or junk it. I'm comitted, or maybe I should be... This board really helps. Thanks so much to everyone!
LOL ernster
I had an 85 monte that did that turned out to be a fuse.Can't remember which one but for the hell of it run through um.I think they did some funky stuff at the factoy,cause my dash lights were fused through the taillight circuit. Found that out when I had no dash lights but a good fuse and got pulled over for no tails.Changed the tail fuse and got dash lights again go figure. [ March 04, 2003: Message edited by: 78 monte ]</p> |
Wow, I got excited and went and checked all of the fuses. I just knew that was going to be it. I guess the tank comes out this weekend. What a pain. By the way, I bought these cool little grounding clamps; clean the surface, then tightend the little clamp to the edge of the gas tank and then to the body. Still didn't work, but the grounding idea made good sense and the little clamps that I found were cool. Lowes home electrical section, I believe they are for grounding your breaker box.
hi dpjmw. just wondered if you ever got it fixed, as i have the same problem with my '70 oldsmobile.
been thinking about dropping the tank in mine, but thought i'd see how your story ended before it comes to that. thanks. [ March 21, 2003: Message edited by: 98rocket ]</p> |
Hey
When you get the tank out, check the assembly with an ohmmeter, attach the ohmmeter to the possitive and neg. on the unit, then move the leaver, if the ohmmeter moves then you know that your unit is good, (Check the wiring doing to the unit) I have had bad wires before, or even bad plugs where it plugs onto the sending unit. Hope this helps for a tip, i love electrical work, but what sucks is that i am colour blind so it takes me forever to do that work, but i love electrical |
Bared wire, perhaps?
I may be wrong, but the way that I understand gas guages is that the sending unit provides the ground, and that a rheostat is used to provide variable resistance.
When the tank is full, the rheostat is in the "fully grounded" position offering zero resistance, and the guage reads "full" At 1/2 tank the rheostat is only supplying 50% of the resistance value... etc So my theory is that if the wire leading to the sender has been chafed and grounded before reaching the sender, it will always display a "full" tank. HTH, Don |
