Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 87 Camaro - Gas gauge stuck - FULL
Old 02-25-2003, 05:02 PM
46_stvblt's Avatar
46_stvblt 46_stvblt is offline
Post
It most likely is a ground problem. Run a seperate wire from the sending unit to a good ground on the frame. I've had this same problem and the seperate ground usually fixes it.....GlennK..
