Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 87 Camaro - Gas gauge stuck - FULL
Old 02-25-2003, 05:55 PM
46_stvblt's Avatar
46_stvblt 46_stvblt is offline
Post
I got your pm but I thought I'd answer you here...There is another way that you may be able to get a proper ground without pulling the tank..On your tank there is a seam lip that runs all the way around the tank where it is welded together. You may be able to drill a small hole in the lip and attach a wire there and then to agood clean spot on the frame. If you have a cordless drill it would be safer to use it other than an electric drill just to be safe and not ignite any fumes that may be around...If that doesnt work you could cut a hole in the trunk floor if you can locate exactly where the sending unit is. other wise pulling the tank is the last option.....On that seam lip go to one of the back corners, the metal is the longest there...Good luck with this and I hope it works...GlennK
