-   -   87 Chevy 350 TBI rod & main Clearance question (http://www.hotrodders.com/forum/87-chevy-350-tbi-rod-main-clearance-question-89806.html)
Mustangsaly 05-19-2006 11:05 AM
what is acceptable rod & main Clearances on a stock 87 Chevy 350 TBI engine ? (this motor was pulled 4 low oil pressure) this will be a all stock budget rebuild on a 87 Chevy 350 with fresh heads. what should ring gaps be ? or is there suggested ring gap from the ring manufactures on stock pistons (hoping I can hot tank this block & just hone the block,time will tell) ? where is good place to purchase a rebuild kit 4 this (mght need cam & lifters to) ? any other other input welcome.
Mustangsaly
DoubleVision 05-19-2006 11:13 AM
If the rings are replacement rings for the stockers than there really is no worry unless there is excessive bore wear. As for the bearing clearences remember this rule of thumb: Anything under .001 is not enough and anything over .003 is too much.
Mustangsaly 05-19-2006 11:28 AM
bout how ponies is this putting out stock ?
Mustangsaly
Mustangsaly 05-20-2006 04:18 PM
any one know stock HP & TQ #s of a stock 87 Chevy 350 TBI engine ?
Thanks
Mustangsaly
