#1
87 Chevy 350 TBI rod & main Clearance question
what is acceptable rod & main Clearances on a stock 87 Chevy 350 TBI engine ? (this motor was pulled 4 low oil pressure) this will be a all stock budget rebuild on a 87 Chevy 350 with fresh heads. what should ring gaps be ? or is there suggested ring gap from the ring manufactures on stock pistons (hoping I can hot tank this block & just hone the block,time will tell) ? where is good place to purchase a rebuild kit 4 this (mght need cam & lifters to) ? any other other input welcome.
Mustangsaly Register now (free) or login to remove ads |
#2
If the rings are replacement rings for the stockers than there really is no worry unless there is excessive bore wear. As for the bearing clearences remember this rule of thumb: Anything under .001 is not enough and anything over .003 is too much.
| Thread Tools | Search this Thread |
| Similar Threads for: "87 Chevy 350 TBI rod & main Clearance question" | ||||
| 1989 Chevy 350 TBI Timing | Primevci | Engine | 9 | 01-31-2009 05:13 PM |
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| 85 chevy 305 heads on an 89 TBI chevy 350? | jazzguitar | Engine | 4 | 11-03-2002 04:11 AM |
| 350 chevy 2bolt main????? | fatherandson53 | Engine | 5 | 10-23-2002 09:37 PM |
| 1989 Chevy 350 TBI | Mikey | Engine | 1 | 05-02-2002 07:45 PM |
