87 Ford AOD conversion to C6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2006, 02:47 PM
My 87 302 ford pickup has a bad AOD trans, I have a C6 that I want to replace the AOD with. Can someone tell me what I will need to do this conversion or point me to a source for info.
Thanks
Old 08-08-2006, 03:56 PM
I do not claim to be a knowledgeable person when it comes to the later model Fords ... but I believe the AOD and the C6 have different bell housings ... unless you have the fairly RARE ... small block bell housing C6.
C6's are well known to use a good bit of power up ... and are one of the worse energy efficient transmissions Ford made.
Old 08-08-2006, 06:27 PM
C6 conversion
Thanks for the reply, this truck is going to be used to haul hay and pull a trailer, not a daily driver, the fuel economy isn't a concern. I am wanting a 3 speed without overdrive hence the C6.
Old 08-09-2006, 05:52 AM
Tominator's Avatar
Although no claim to expert status either, my '77 F100 has a 302 w/C6 and I'd think they are rather common.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Ford C6 matchup to 351W? jcharlt2 Transmission - Rearend 3 01-03-2006 08:40 AM
ford 400 with c6 trans... 68novafan General Rodding Tech 11 12-14-2005 10:56 PM
AOD Ford tranny (lost fourth gear) shagginwagonvic Transmission - Rearend 8 10-13-2002 01:48 PM
AOD ford transmission melbishop Transmission - Rearend 9 04-11-2002 12:29 AM
