87 Ford AXOD Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2007, 01:39 AM
87 Ford AXOD Trans
Ok,
Need some help please. The AXOD trans in my 87 Taurus just started blowing stinky white smoke. I believe its burning auto transmission fluid. Car was very recently added as cheaper transportation. I serviced the tranny w/ new filter and fluid and it worked. However, it seems to slip some occasionally at lower speeds. Now with this smoking problem it leads to believe I now have a bad modulator valve on the transmission. I don't know where or even if this unit has a modulator valve. I went looking for a replacement modulator valve and couldn't even find a source to obtain one. Any ideas? Problem or Source?
Thanks,
Kent
Old 07-12-2007, 06:09 AM
87 axod
The AXOD does not use a modulator, instead it uses a cable as a load sensor, [ for line pressure rise ].
I would suspect an inconvenient catastrophic failure, related to the engine.
After all, remember, it is a Ford.
C4 trans in a '57 Ford, What tranmission Mount? RAW Transmission - Rearend 4 04-12-2007 10:02 AM
1989 Ford Mustang and 87 Ford Bronco fordman83 Introduce Yourself 4 03-23-2007 10:54 PM
87 Ford Ranger oldsmo Engine 2 11-15-2006 06:03 AM
Ford automatic trans. slipping 87442lover Transmission - Rearend 3 02-18-2004 11:26 AM
1964 Ford Falcon Trans slip into 2nd whytyewytche Transmission - Rearend 0 11-27-2001 05:13 AM
