Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 87 gm tbi will not start
Old 12-28-2012, 11:42 AM
Matty8 Matty8 is offline
I checked the balancer marks and they are correct. I've had the valve covers removed to verify that the engine is on the correct stroke and the distributor is not out 180 degrees. When I crank the engine I can see fuel squirting from the injectors. This is why I'm confused. Everything seems to be working but it will not start. That's why I'm wondering if a sensor is out of wack and throwing the mixture way off.
