87 gn motor into a 86 cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2011, 10:30 PM
can i put a 87 gn motor into a 86 cutlass if so what do i gotta change
Old 04-01-2011, 09:15 AM
busted knuckles
87 gn? Exactly what kind of motor? And what did the cutlass have in it?
Old 04-01-2011, 10:16 AM
This has been done before. The GN and Cutlass use the same frame. You need to swap EVERYTHING from the donor car, including frame mounts, motor mounts, wiring, computer, fuel tank (with pump), and trans. Your stock trans will not survive the turbo motor.
Old 04-01-2011, 10:18 AM
Ditto for the rear end. Find a GN rear end as well.
Old 04-05-2011, 12:44 AM
thanks every one actually i found a 85 gn motor v6 turbo 3.8liter and my cutlass has a 307 5.0liter and im not sure if it has the 7.5 rear end r the 8.5 rear end n about how much yall think i will end up payin in parts n the labor n etc and could i use a 84 buick t-type regal fo parts if it has the turbo v6 in it..and if i buy the 85 gn motor wat should i check n etc...but thanks fo all the info need it
Old 04-05-2011, 03:18 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Only the GN's and 1 or 2 years of G-body 442's came with the 8.5" which makes them pricey if you find one and the seller has any clue what it is. I've seen people asking $1,000 for an empty housing with axles. Doesn't mean they got it but they knew it was rare. It would be as cheap to have a regular 8.5 housing cut down to fit and brackets added. I was going to have one cut to GN length for a leaf spring car and add aftermarket axles but I found a factory Dana 44 posi that was a bolt in. Of course by the time I was done refurbishing it and swapping gears I had just as much in it.
I don't think the T-Type Turbo Regals got the 8.5 but don't quote me on that, I don't know for sure. I looked at a Turbo T-Type a few years ago with thoughts of doing a "detuned" GN look alike project with one of the boys and it did not have the 8.5. None of the Turbo 3.8 Monte Carlos I have looked at had the 8.5 either.
Old 04-05-2011, 03:22 PM
The only G-body cars with 8.5" axles were the 1984 Hurst/Olds (3.73:1), 1985-87 442 (3.73:1), and the 1985-87 GN (3.42:1). All other 1978-88 A/G body cars got the 7.5 axle.
Old 04-05-2011, 03:29 PM
Here's a link to one for sale on Chicago craigslist. Looks to be built. I've seen them for $800 on the low side and up to $2K. They are strong. My son has a 86 GN that runs low 12's stock 8.5 with no issues.
http://chicago.craigslist.org/nwc/pts/2296202614.html
Old 04-06-2011, 11:42 PM
so would the gn rear end bolt rite up to my 86 4 door cutlass yall think
Old 04-07-2011, 12:57 AM
ericnova72's Avatar
More for Less Racer
Yes, it will bolt right into the chassis, but the driveshaft will have to be shortened a little bit, the 8.5" rear is a little longer out the front of the pinion nose.
Old 04-08-2011, 12:36 AM
You can do ittttt!
Old 04-14-2011, 02:52 PM
man dats nice rite there and sum one told me the gn motors r a pain in the u kno and sshould i go wit the gn motor r get a ls1 and call it a day so wat yall think i should doo
Putting a Grand National Motor in a Cutlass ChrisMiddleron Engine 8 04-01-2011 09:54 PM
78 cutlass workman306 Introduce Yourself 2 11-27-2010 04:52 PM
Chevy motor mounts won't line up in my Cutlass labreejr Engine 10 11-23-2010 06:33 PM
A 500 BBC Motor in a Cutlass ChrisMiddleron Engine 4 03-14-2006 07:54 PM
1986 Cutlass Motor mount and vacuum line questions ChrisMiddleron Engine 8 05-19-2005 01:51 PM
