Thread Tools Search this Thread share on Facebook
  #46
Old 03-30-2009, 08:37 AM
DaSouthWon's Avatar
DaSouthWon DaSouthWon is offline
I put up the tools against$300
The stamped rockers used on 87+ L98's are self aligining. As you stated above, you only need one of the 3 ways to align the pushrods. Either slots in the heads, self-aligining rockers, or guide plates. GM put plates on the heads and installed self-aligining rockers. FWIU the plates are not functional as guide plates. So, if he put non-self-aligning rockers on he's got a push rod thats wobbling back and forth, probably against the plate creating the vibration and squeak.
Register now (free) or login to remove ads
Old 03-30-2009, 08:58 AM
Calderone Calderone is offline
thanks so much cobalt !!!
Old 03-30-2009, 09:09 AM
DaSouthWon's Avatar
I googled the casting number on those heads and plates and came up with this: L98 Retainer Squeak . I think this guy has the same problem you have.
Old 03-30-2009, 09:13 AM
wow this is getting more and more confusing ....
Old 03-30-2009, 09:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
I'm following you.
What's the great unknown here is what type of rocker is being used...
The link above doesn't want to work for me, can you post the url?
Edit- Nevermind. I think the prob's on my end.
Old 03-30-2009, 09:30 AM
If GM put SA rockers on the 128 heads
anything bad could happen if i switch to NSA + GUIDEPLATES ?
Whats the visual difference with a Stamped SA an NSA ?
Thanks
Old 03-30-2009, 09:34 AM
remember i have the zz4 cam...should i replace the studs ?
Old 03-30-2009, 09:35 AM
DaSouthWon's Avatar
Old 03-30-2009, 09:38 AM
Yes i saw that link..so i think i will be fine with NSA + guideplates.-
Now about the pushrod...which lenght is recommended ????
thanks
Old 03-30-2009, 09:45 AM
DaSouthWon's Avatar
The rocker arm tips have a notch which the valve stem tip sits in to keep it centered.
Old 03-30-2009, 09:52 AM
Got it !
SA on the left ...NSA on the right !
i think i will use NSA because my valves IIRC doesnt have that little head
for the SA to align
Old 03-30-2009, 09:57 AM
DaSouthWon's Avatar
Except yours are stamped if they're stock. No roller, but yes. If you do use the NSA rockers put in real guide plates and hardened pushrods.
Old 03-30-2009, 10:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
for the SA to align
You might have less of the valve tip showing if the valves were cut during a rebuild. But it's there.
And if the tip was cut, this could allow a SA rocker to contact to top of the retainer. That could cause the squeak, as mentioned.
Non SA rockers and hardened p-rods w/proper g-plates it is, then!
BTW, I wonder how well the nylon-like guideplates work. Supposedly, you can use non-hardened pushrods w/them.
AFA p-rod length goes, there are length checkers that are inexpensive that'll let you measure for the correct length. Comp has them, IIRC. Others as well, I'm sure.
You want the swept area of the valve/rocker tip to be centered on the valve tip.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "87 L98 TPI "pee pee pee pee" noise coming from the valves"
ThreadThread StarterForumRepliesLast Post
Strange noise on 1987 L98 TPI Corvette engineCalderoneEngine1607-24-2008 04:48 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
