87 Lincoln Rear Caliper Banjo Bolt Size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 05:42 AM
Last journal entry: Journal Update
Does anyone know what size banjo bolts are used on a 87 Lincoln rear caliper?
I have run into some trouble figuring out what size I need for those. Any ideas how to go about this?
I am running stainless steel flexible brake lines with banjo connectors from the calipers to the frame. I need to order the right parts, but most of the aftermarket brake part companies are of no help, willing to sell the parts, but not willing to figure out what size is needed. Any input would be appreciated!
Old 08-30-2006, 12:55 PM
aka Duke of URL
The FORD Standard Hardware PN is N801052-S100. It is not listed in my only early edition. You can take this PN to a dealer and they should have the necessary issues to cross reference this PN to size and type.
Is this a LINC or MARK?
Old 08-30-2006, 01:00 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It is more than likely a metric size. Take your caliper with you to NAPA....they have a bin with small drawers full of different size banjo bolts. look and try untill you find one that fits. Be sure and get the copper sealing washers also.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
I need help with ID of a 12 bolt rear end Please ! rr67gto@aol.com Transmission - Rearend 9 03-19-2006 03:36 AM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
