'87 monte carlo question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 03:41 PM
I am looking for a wiring harness for my 87 Monte Carlo, I am having a 350 put in but need a harness. I currently have a 305 tpi harness. My question is will an engine wiring harness out of an '85 camaro 305 carburated automatic do the trick.
Thanks for the help.
Old 03-06-2011, 04:06 PM
LATECH's Avatar
All the wiring you need is allready on your car. It would be cost effective if you studied the diagram.You can leave what you need and remove what you dont.You dont need any other harness. You will spend more time fooling with that than if you learn the harness you have.
I see it here all the time. sometimes you need a different harness, I dont think this is one of those times.
All Data DIY should be able to supply a diagram.
Old 03-06-2011, 04:09 PM
LATECH's Avatar
the computer part of the harness comes from a seperate place than the basic wiring for the car such as lights and the horn, ignition power, starter etc.
Take a good look at it you will see what I mean.
Keep an open mind.
To buy or not to buy, Monte Carlo is the question 58lincoln Hotrodders' Lounge 16 07-15-2009 02:25 PM
82 monte carlo rearend question 82montecarlo Transmission - Rearend 3 07-02-2007 09:31 PM
Question about a monte carlo rear end... Mike_82 Transmission - Rearend 3 10-29-2003 09:38 PM
Monte Carlo Engine Swap question Dans83Olds Engine 4 10-07-2003 09:45 AM
