87 Monte SS Rear differential Casting Numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2008, 07:28 PM
Hey guys..
any help would be greatly appreciated. I have a 87 Monte SS, unfortunately found out I have a NON posi unit. The casting numbers are
2TF C 302 2
I can't find anything on these numbers as far as axle ratio, or size or anything. I want to stick a posi in it just need to know what size. Thanks again for any help givin.
Old 06-13-2008, 07:07 PM
Does the housing have two "fangs" at 5:00 and 7:00 like this one?
If so, it's the GM 7.5" rear end, which is not very strong, but might be OK if you don't beat on it real hard.
You'll need to know what ratio the gears are before buying a posi unit.
85 monte carlo rear differential what's these number mean hddave1 Transmission - Rearend 2 04-18-2008 09:29 PM
'87 monte ss gears '87 monte ss Transmission - Rearend 12 10-16-2003 05:21 PM
83-88 Monte SS Rear end tsorens Transmission - Rearend 5 01-26-2003 03:21 PM
rear end casting numbers dill Engine 2 01-02-2003 05:59 PM
monte carlo v6 rear end ? 85irocss Transmission - Rearend 1 08-22-2002 02:11 AM
