Here is the larger solid roller cam specs:
Grind Number CS XR280 R-10 Description -------------------------------------------------------------------------- Intake Exhaust Valve Adjustment 0.016 0.018 Gross Valve Lift 0.570 0.576 Duration At 0.015 Tappet Lift 280 286 -------------------------------------------------------------------------- Valve Timing At 0.015 Open Close Intake 34 66 Exhaust 77 29 -------------------------------------------------------------------------- These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.050 242 248 Lobe Lift 0.380 0.384 Lobe Separation 110 -------------------------------------------------------------------------------- Recommended Valve Springs 977-16 |
i have a 10.5-1 406 but with the gas prices now i opted to build another 9.4 motor to run on 87 octane.i've read alot of magazine articles by all kinds of engine builders and i agree hole heatedly that there is power to be had at that level of octane.the roller cams and alum. heads are a big plus in that area.if you go to AFR.COM,then click on articles,drop down down near the bottom of the sbc list you'll find one that says "412 H.P.350 c.i. afr 190 cc",hot rod ,june/97.the name of the article is,"the 350 engine chevrolet should have built".they build an engine under tight constraints money wise and performance wise but still come up in good shape for power and torque cheaply and use 87 octane.if you pay close attention you'll see where many performance parts can be swapped in to make big power still with 87 octane.
So nobody has any idea of the approx HP my current combo has? My guess about 425. How about after the proposed changes?
Anyone have any quarter mile estimates with 28x10.5 slicks? Depending the attained speed I could cross the finish line in 2nd over (1.15 to 1) instead of direct (1 to 1) due to the Gear Vendors OD. The motor turns 6600 no problem but since I don't know where the HP peak is I could be shifting it too late. Any good ideas or suggestions? |
Power is affected by more variables than we can see on your list. But your power should be very good.
Cranking compression is determined not only by static calculated compression ratio but also by the intake valve closing point. Your cam is advanced 4* as installed and lengthens the dynamic compression stroke. Retarding the cam to straight up will reduce cranking compression and bias the torque curve to a slightly higher (200) rpm. Installing a longer duration cam will assist in moving the power peak upward, and if the (cam timing) intake valve closing point remains the same as the other cam, the cranking compression will remain the same since the dynamic compression stroke is still the same length, but of course the power curve will be moved higher and the low rpm might feel a little soggier. Of course stepping up to a roller and its more agressive ramps will make more power across the board. http://e30m3performance.com/myths/mo...comp_ratio.htm Last edited by xntrik; 01-20-2006 at 11:01 PM. |
| CA smog questions...engine swaps | curtis73 | Engine | 25 | 11-28-2012 08:11 PM |
| Engine Choice, Please Help | savman1 | Engine | 1 | 01-12-2006 09:36 PM |
| 326 firebird engine swap with a 400 engine...is it possible?? | greg67 | Engine | 7 | 11-08-2003 03:34 AM |
| 87 El Camino engine swap | lscott046 | Engine | 1 | 01-31-2002 08:19 PM |
| Engine swap | gcusick | Engine | 7 | 11-14-2001 03:11 PM |
