87 s15 v8 wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 08:16 AM
New Member
Post 87 s15 v8 wiring
That sounds good, i was also wondering about wiring to distributor, 77 pu has 3 wires to plug.....jimmy has 4?????? Is this going to be a problem or easy to solve. Another question i have is the jimmy has a sensor in the exhaust manifold, what needs to be done with that? Any help would be great, thank you
Old 11-12-2002, 05:34 PM
BOBCRMAN@aol.com's Avatar
Post
the sensor in the manifold is an oxygen sensor, the 77 won't need it, the distrib you will have to sort out the color code and hook up 1 less wire. actually if the early distrib has a vacuum advance you should only need one wire to it,hot from the ign switch.
Old 11-13-2002, 08:01 AM
New Member
Post
Thank you Bob, i will see if i can make it work(electrically challenged)
