87 suburban losing fuel need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2009, 03:41 PM
i have an 87 chev suburban it has been running great and we took a family trip or started to and it just lost fuel and died it restarted revved up made it about 50 foot and died again we changed the fuel filter and it started up and made it home and then died again. this morning we replaced the fuel pressure regulator started it and it made to the corner and died again. the fuel pump is coming on when you turn on the key bit it is not always getting fuel. then it will start again and idle fine. then as soon as you take off it dies again and loses fuel any suggestions please let me know thanks
Old 01-12-2009, 10:41 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
It sounds to me like the pump is heading south. Best bet would be to drop the tank, clean it, and repalce the pump. Some of the pumps have a fine mesh filter around them, but it takes quite a bit to completely plug on of them. And a pump going bad can still sound like it is working, but it will not pump the fuel. If I had known a month ago I could have given you an almost new on that I had in the cabinet out of an '87 Truck, but I got rid of the stuff I didn't need. Ain't that the way it always goes?
Old 01-12-2009, 12:49 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I would say your pump is in need of replacement, a fuel pressure reading at the throttle body inlet pressure test connector will confirm or deny this.
Nitrous fuel supply ??? 67 Deuce 4 Me Engine 6 11-11-2007 10:30 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
Need help building a fuel system. staleg General Rodding Tech 1 05-16-2007 02:13 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 05:36 PM
questions about fuel system for a 434 small block chevy tony350ss Engine 4 08-27-2003 12:02 PM
