87 454 TBI has other issues like running rich but that's probably unrelated.
Always started fine but from one day to the next has decided to start blowing the IGN fuse as soon as I turn the ignition on.
Poured some fuel down the TBI and it ran a few seconds, so spark not the issue, fuel delivery.
Crawled under the Suburban and found a wiring coming off the pump. One black, white and one purple. Hooked up a wire to the +12v on the battery straight to the pump and presto starts right up and runs. (also my fuel gauge seems to be grounded out as it shows way over full all the time) maybe the 12v to the fuel pump is grounding out too?
What else is on that IGN 12v?
It's worth noting that once that truck has a run a few minutes and is switched off the fuel pump makes a ticking noise that sounds like a bouncing marble coming directly out of the fuel tank.
Anyways, what could be grounding out? Or is it the obvious? Anyone have a daigram on these motors of which wire is which? If I could get my fuel gauge fixed to that would be a bonus!
thanks in advance,
thanks in advance,
