Thread Tools Search this Thread share on Facebook
  #1
Old 04-11-2009, 06:14 PM
jlbrost jlbrost is offline
88 350 tbi engine upgrade
i have a 1988 chevy blazer with a stock tbi 350, i want to put a 350 that is bored .030 over has has vortec heads and a comp 4x4 extreme cam in it. i know i will have to change intakes to bolt my tbi on but i dont know what to do to make the computer work with that engine. i have been told i just have to change the cam to one that is made for the computer but im not sure if i need to do anything else or not
Register now (free) or login to remove ads
Old 04-11-2009, 06:39 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
To use a TBI with that many mods you will need to have it dyno tested so a new chip made for that set up can be burned. The vortec heads far outflow the swirl vane stockers that came in these trucks, and it won`t be close to right unless you have the right chip made. The cheaper alternative would be to go backwards to a carb. You will likely also need higher flowing injectors as well as installing a vacuum controlled adjustable fuel pressure regulator.
Old 04-11-2009, 06:51 PM
Mike H Mike H is offline
About 216 @ .050 is all a TBI engine wants to get it to idle. They hate cams with any more duration.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "88 350 tbi engine upgrade"
ThreadThread StarterForumRepliesLast Post
the history of chevy v8'ssavman1Hotrodders' Lounge4303-02-2012 06:57 PM
Distributor Tuning and Theory - Part 1Rick WIEngine3504-26-2011 12:38 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'EngineOldsmolac911Hotrodders' Lounge5001-12-2011 10:00 PM
Very "lazy" '88 350 TBI helpnewsuburbaniteEngine912-01-2003 05:57 PM
350 chev engine numbersforpetesakeorgTransmission - Rearend208-18-2003 07:11 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
