88 700r4 accumulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2011, 01:28 PM
Rebuilding an 88 700r4 for performance street use. I plan to replace the the 1-2/3-4 accumulator piston with the pinless type, my question is the Aux valve body....can I use the pinless unit in there as well. The valve body is scored as is the one from a parts trans. so I will have to replace the body but the pinless question is still applicable. Any thoughts?
Glenn
Old 05-09-2011, 02:17 PM
700r4 pinless pistons
I mis-spoke, it is my 1-2 housing that is scored and needs replacing. So again can/do I use pinless pistons in all 3 locations?
Glenn
Old 05-09-2011, 06:34 PM
really not necessary to put the pinless piston in the 3-4 accumualtor your best to just put the spring in first and then the stock piston on top of it against the sep plate this will remove the 3-4 accumulation.
Blocking 2-3 Accumulator nova69 Transmission - Rearend 4 01-09-2009 11:27 PM
700r4 accumulator question oldchevy1956 Transmission - Rearend 2 05-04-2008 04:43 PM
700R4 Accumulator and auxiliary valve body TpiRegal Transmission - Rearend 4 03-27-2008 01:22 AM
700r4 accumulator pistons Elcamino70 Transmission - Rearend 16 12-22-2006 06:22 PM
700R4 3-4 Accumulator Piston Removal Bruce M Transmission - Rearend 2 05-10-2004 09:24 AM
