$88.88 air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 08:17 PM
I picked up a cheapo mini aircompressor for my Dad today, he needed something he could move around easily that would handle the air supply needs of a touchup gun used in his woodwork projects. Advance Auto Parts had this listed in a recent sales flyer at $88.88 and it's rated at 2HP with an air supply rating of 4.6cfm@90PSI with a 110 power supply. The air supply sounded like enough for what he needed so I bought it and took it home for testing. I've got to say for the price and size I am really impressed how this little jewel works. I turned it on, plugged a hose in and dialed in the regulator. It keeps up with a touchup gun without problem. I loaded my gun with paint and shot a firewall and dash with it with no problems. Then I plugged in a standard sized gun and filled it with water and ran it nonstop till the cup went dry noting the air pressure. Although it's not large enough for continual use with a full size gun it would be fine for most primer work in my opinion. With a touchup gun painting small parts, motorcycles, and single panels it works just fine.
Bottom line is, if someone on a budget wants to work on their ride it can be done with tools like this.
Old 02-08-2006, 08:28 PM
milo's Avatar
point on positive
something to pass along and remember is the little vent hole on some of those constantly spews oil mist into the air and can cause paint related problems if running in the paint area.. Fisheye problems have been traced back to that source.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Crappy Air Compressor Wont work rbfpezcore Garage - Tools 7 06-12-2005 02:24 PM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 10:17 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 06:24 PM
