88 AOD tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2003, 03:23 PM
New Member
Post 88 AOD tranny problems
I'm new to this forum and I've read through some of the posts concerning the AOD tranny. I've seen many people have the same upshifting problem I'm having. Here's my setup.
I have a newly rebuild AOD tranny with a 302 in my '73 Bronco. I'm using the Lokar TV cable. I installed the cable and trailered the Bronco to a local tranny shop (recommended by a friend of mine). They hooked up the pressure gauge to the TV pressure port and he adjusted the cable to the correct PSI. We then took it for a drive and noticed that it wouldn't shift out of the gear you started in. For example - you start in 1st you stay in first, you start in 2nd you stay in second or you start in D you stay in 1st. So when we get back to the shop we look at the gauge and the PSI is up to 30PSI at idle in Neutral (if you put the adjusting block on the TV cable at the carb the gauge would read 90PSI).
The tranny guys there said it was probably a stuck governor. But I spoke with Baumann Engineering and they said it is a stuck valve in the valve body. The tranny sat for almost a year after the rebuild prior to me getting the Bronco running again. They (Baumann) suggested that this could likely be the reason this happended.
I bought some LubeGaurd (supposed to free sticking valves) but I haven't had a chance to try it out (need to drain some fluid first to make room for the lubegaurd). Getting the the governor would be a pain because I have to remove my transfer case to get to the rear of the tranny. I have no idea if my rebuild included a new valve body. I can't seem to get in touch with the yo-ho that rebuilt my tranny.
I found a flowchart that talks about this tranny issues and it lists both the governor and valve body as possible issues. <a href="http://www.jasperengines.com/flowtran.pdf" target="_blank">http://www.jasperengines.com/flowtran.pdf</a>
I'm not sure what to do. I don't want to spend a lot of time to remove my tcase to get to the governor if I need to be working with the valve body. It seems to me that the TV valve is stuck causing the high TV pressure. But that's just me and I don't know much about trannies.
Thanks for reading this book.
Ryan
Old 02-10-2003, 03:27 PM
5.0Towncar's Avatar
Post
Try the Lubeguard stuff or whatever anyone else suggests. I have put iver 2600 bucks into my AOD(2 rebuilds in 3 years) The first rebuild was horible but the second one I got is pretty strong. Try simple troubleshooting stuff before yanking out parts.Steve
Old 02-10-2003, 04:02 PM
Post
I have had trouble with both valve body and gov. cured most by just driving and shift manualy until trany starts working on its on, just dont force any shift let trany shift on its on, if you know your taking off in second dont try to force the engine to pull the truck like it was in first.add the adative and drive on a less travled road or stree tbe start and stop can get crazy in traffic good luck.
Old 02-10-2003, 05:25 PM
mustang66maniac's Avatar
Ford Freak
Post
I bet you its the stuck TV piston in the valve body. I don't know if you read the thread about my AOD, but it turns out that was the whole problem. One of the plungers in the TV part of the valve body would get stuck. When in neutral at idle, it would be at 0 at first but then when you give it gas/pull the cable, it would shoot up to 90 and then stay there no matter what. What i did was i went to pic-n-pull and got an 89 valve body. 88 and 89s are a bit different but it will still work in your tranny. Ford upgraded the valve body i think 24 times between 1982 and 1993. Basically, the later the valve body, the better it'll work.
I think if i were you, i would either get a manual that has detailed pictures of all of the plunger/spring assemblies in the valve body, then take them all out of the TV portion of them, clean them with carb cleaner or brake cleaner, and lube it up with vaseline and put it back together. OR you can just pick up a later model valve body.
Old 02-10-2003, 08:57 PM
New Member
Post
Thanks for the info guys.
I do have a good manual from ATRA that has all the info you need to tear this tranny apart and put it back together. I'll try the additive first and then work with the valve body.
I'm sorry to hear others have had this same issue but at the same time I'm glad that you guys can share your experience to help me out. Thanks again. I'll keep everyone posted on the results.
Old 02-10-2003, 09:54 PM
aka Duke of URL
Arrow
AOD Pressure Regulator Boost Valve Kit
This high quality valve and sleeve, manufactured by Sonnax, cures many line pressure related problems in the AOD transmission. Sticking or worn boost valves are a leading cause of failures and shift complaints with the AOD transmission. Over time, the steel valve will wear into the aluminum sleeve, causing the valve to stick and leak. Since the boost valve is responsible for increasing line pressure to match engine torque, it is obvious that the condition and calibration of this valve are even more critical in performance applications.
This "better than new" replacement sleeve is manufactured from wear-resistant Deltalloy 4032 and is sealed to the bore with O-rings, unlike the original equipment sleeve. We recommend replacement of this valve during the installation of our valve body kit, or especially in a high mileage transmission or during an overhaul where contaminants will have accelerated the wear of the original valve even further.
Catalog Number: BV-AOD
Baumann Engineering-[/b]</a>
<a href="http://www.tciauto.com/instructions/431000_inst.htm]-AOD TV Cable Adjustment-
Old 02-12-2003, 04:28 PM
New Member
Post
Well I tried the LubeGaurd and I don't think it's going to do anything. I put about 1.5 miles on it and my pressure is still reading high - about 75PSI at idle in Neutral.
Should I put more miles on it? I would think at this high of TV pressure it would be like having your TV cable way out of adjustment so driving it like that would be a bad idea.
I think I'm just going to pull the valve body and clean it out and put it back in. Then I'll give it a try again.
[ February 12, 2003: Message edited by: rflud ]</p>
Old 02-12-2003, 06:59 PM
Ford Freak
Post
yeah dont drive it, if you do youll be doing more harm than good
Old 02-12-2003, 10:44 PM
New Member
Post
Well, I only have 3 1/2 mile on it now so I think I'm still ok. I'm just going to pull the whole thing and take it to the shop. I don't want to deal with it. No telling if I'll get it riht the first time or not and I really don't want to ket messing with it.
It's been two years since I have really driving this thing and I'm sick of it sitting in the garage. It's time to start driving it!
Old 02-17-2003, 04:53 PM
New Member
Post
Here's and update
This is just me venting -
I bought an AOD tranny from a transmission shop here in town back in Nov 2001. I installed it into my chassis and there it sat while I finished other things - body, wiring, etc. I finally got the EB ready for a test drive in late Jan 2003. The tranny wouldn't shift out of first. I took it to a tranny shop (a different one than the guy who built it - you'll see why soon). They did some checking and there was clearly a problem. At this point I have 1.5 miles on it.
So I try to contact the guy who built it and I can't get in touch with him. My messages go unanswered, my visits to his shop unsuccessful. He is now where to be found. But I just spoke to him a few weeks earlier and his answering machine is still picking up the phone calls so I assume he is still in the area.
So I decide to pull the tranny and take it to the shop that a friend of mine knowns (he goes to church with the owner). They pull it apart and Mike (the tranny guy) walks me from one end of the work bench to the other all the while showing me what is wrong with this tranny. Worn out clutch drum, sun gears, etc. Hardly anything was new in this tranny.
So I'm basically screwed. I can't get with the original builder and from what I've now heard he is known for this and wouldn't stand behind his work anyway. I will be having this new shop fix everything. Probably going to cost me $1000-1500 to get it all straightened out. Then I still have to install it. I am not happy at this point.
