the key goes back to an off position or the engine dies after startup?
Voltage is King, and most important when a vehicle is stored for even a couple of months. |
It could be the electrical portion of the ignition switch is coming apart, but I can't stress double checking the battery cable connections enough.
Yesterday I checked why a 2000 Ford Explorer Sport 4.0L would not pass the smog test. Codes P0171 and P0174 too lean banks 1 and 2, which were the failed smog problem. I cleaned the dirty mass air flow sensor, and sent him on a drive that would set most of the monitors to "ready" in the computer. He came back with a complaint of low on power and miss firing with the check engine light on. It had codes for cylinder's #3 & 5 miss fires and a coil pack power fault problem. I cleaned the battery cable connections, and sent him back on the same route. He came back saying it ran perfect and his alarm and door locks worked better, and the check engine light was not on, and all of the monitors were set to ready. He left here and went to the "smog only" and it passed with perfect numbers. JMO |
| All right all you Ford guys, a couple of questions | Shades_o_Grey | General Rodding Tech | 8 | 12-28-2010 06:00 PM |
| Ford Muscle..what's wrong with them? | tm454 | Hotrodders' Lounge | 41 | 11-20-2006 12:37 PM |
| Ford Rear Discs, revisited. DONE! | Psquare75 | Suspension - Brakes - Steering | 39 | 07-18-2006 06:10 PM |
| M.S. requested joke thread | hotrodit | Off-Topic | 186 | 12-20-2005 12:26 PM |
| will 88 Tbird fenders bolt on to 83 t Bird | V Bird | Body - Exterior | 2 | 12-06-2003 09:18 PM |
