88 ford bronco 2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 01:36 AM
88 ford bronco 2
We have changed the coil , put in new fuel pump the one in the tank, and changed the module and still no fire to the coil. what are we missing?
Old 04-15-2006, 01:52 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Welcome
When you say no fire to the coil, are you saying there is not 12 volts to the + terminal????
You will have to trouble shoot the system and determine where the 12 volts is suppose to be getting to the + on the coil. You could even have a bad ignition switch.
Old 04-15-2006, 03:27 AM
65Stanger's Avatar
Check the water, check the oil
You have to take a voltmeter and go from point to point to point. Don't guess and check. You'll find the problem.
ford bronco hyd clutch conversion. Jared Transmission - Rearend 2 11-07-2007 05:00 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
SBC into 88 Ford Ranger Ext. Cab Kenny13z3 Engine 1 05-28-2005 08:20 AM
2.3L 88' ford ranger reliable? problums? Kenny13z3 Engine 10 05-21-2005 11:01 PM
'88 Ford 302 EFI CustomFord Engine 1 04-14-2003 04:46 AM
