88 Fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2012, 03:28 PM
88 Fuel pump
Truck set up for 5 years.Had trouble with fuel pump,Turns out it was a ground issue.Well 5 days later fuel pump not responding.Replace fuel pump assembly and relay,still no responce from the pump.Any ideas I should try?
Old 05-18-2012, 03:45 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
no gas
You must not be getting power to the pump. Check for a blown fuse with a test light.
If the engine cranks over OK the battery is probably OK.
Depending on the vehicle, the system that energizes the relay could be at fault such as a ECM (engine control module) or oil pressure switch.
The relay can be test jumpered but you need to know the power wiring for that vehicle.
vicrod
Old 05-18-2012, 05:21 PM
Joe G's Avatar
If it's a Ford with EFI, the inertia switch may be tripped or defective.
Old 05-18-2012, 07:47 PM
LATECH's Avatar
Or the pump died a varnishy laquered death after ground path was ressurected after 5 years of setting in the weeds.
Need to check the wiring over more, check for voltage back at the pump when turning on the key ( 2 second prime pulse)
If its getting power , have the wife crank it over to start it and pound on the bottom of the tank while she is cranking it. Maybe it will start, if it does, change the pump. The connectors can also corrode and burn up at the pump in the tank. FWIW
Fact is stranger than Fiction
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
