88 royale popping sound from rear when brakes applied - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2006, 05:04 PM
Hello I got a 91 olds royale that popps in the rear when brakes are applied moderately.......I thought it would be drums cracked or warped..so I replaced those but it still does it............a single continious pop each time the tire goes completely around until stopped.........I have never run across this kind of a problem before, has me kinda stumped.
Old 09-29-2006, 08:28 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
brakes popping
How are the backing plates, any groves where the brake shoes ride?
Russ
Old 09-30-2006, 05:22 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Grooves in the backing plate is a good place to check. I've also seen a machining groove in the drum cause this, though those were drums that had been turned and the tool bit wasn't removed from the drum face before screwing the tool post back out. The groove acted like a screw and would "screw" the shoes out when applied. Once to the end of the groove the drums snapped back.
Ford Rear Discs Cobbled Together Psquare75 Suspension - Brakes - Steering 34 11-21-2005 03:47 PM
Engine Stumbles when Brakes Applied lakeroadster Engine 7 08-20-2005 09:14 PM
87 iroc rear disc brakes dont work camarofreek Suspension - Brakes - Steering 4 07-18-2005 10:10 PM
REAR DISC BRAKES BIGBLOCKSTANG Interior 1 10-30-2002 03:41 PM
disc brakes on 62 olds supper 88 fly82_99 Suspension - Brakes - Steering 0 05-15-2002 11:03 PM
