88 s-10 carrier bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 12:23 AM
i have a 88 s-10 with a 350 in it and a 700r4... its lowered 3.5 in all the way around and i am a problem with the carrier bearing going out... i just replaced it a month ago and its already out again... anybody have and suggestions
Old 01-25-2010, 04:01 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
When you say "carrier bearing" are you saying you have a 2 piece driveshaft with a carrier bearing or are you talking about a bearing in the tranny or a rearend bearing?
Old 01-25-2010, 07:09 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Chances are, you need to shim the carrier bearing up off the crossmember to get your driveline angles closer to where they need to be. How is it lowered? Have you checked your pinion angle? Most lowered S10s have the pinion angle WAAY off, if you're using blocks, they should be angled, not square. I do not recommend blocks, drop springs are a much better way to go.
Old 01-25-2010, 02:50 PM
yeah they are blocks and it is a 2 piece driveshaft
Old 01-25-2010, 05:32 PM
prostreet6t9's Avatar
Differential/Driveline
Have you double checked to make sure the D/L was not to long after the truck was lowered?
10 bolt rear end question 8.2 or 8.5 ?? nheron Transmission - Rearend 6 03-02-2008 09:16 PM
12 bolt carrier in a 10 bolt housing wagonman65 Transmission - Rearend 8 01-02-2008 03:54 PM
10 bolt chevy rear end question powerrodsmike Transmission - Rearend 3 09-15-2007 11:00 PM
12 bolt with 10 bolt carrier? JamesRS Transmission - Rearend 3 01-17-2005 09:59 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Introduce Yourself 1 09-14-2004 10:26 PM
