88 Thunderbired Question, Need Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2003, 05:49 PM
Unhappy 88 Thunderbired Question, Need Help
I need help with a problem on my 88 Thurnderbird.
When I let go of the ignition the moter turns off! Seems like the ignition switch is shot. Any ideas or methods I can do will be greatly appreciated. Thanks Mike Smith
Old 08-13-2003, 06:40 PM
adtkart@aol.com
Change the ignition switch. I just had the same problem with my mother-in-laws car. My son changed the switch and took care of it. Was told by several people at the Ford dealer that it is a common problem with the column switches. Note that it is the switch itself, not the key cyl.
Old 08-14-2003, 04:18 AM
There was a recall (due to fires) on the ignition switches on those cars. Give you VIN to a Ford dealer & they should be able to tell you if it has been replaced already. If not, maybe they would fix yours. Also, the switch may be loose on the column.
Old 08-16-2003, 05:50 PM
Talking uslogic
Thanks Guys, I'll take your advice and let you know how it works.
