880 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2013, 08:03 PM
whojohnjones's Avatar
880 block
OK do all 880 blocks have roller cam? What year did they come into existence?
Old 09-15-2013, 08:20 PM
jokerZ71's Avatar
Wrench Turner
The 880 block comes in various forms of roller ready.From completely finished to only having the spider bosses cast.Some have the machining for the lifters done.Some have the bosses only as cast'some are only drilled,some are drilled & tapped.If it was a car engine ,it most likely is complete.Anything after 96 is likely to be complete.
Old 09-15-2013, 08:26 PM
OK I haven't took intake nor valve covers off. I want to upgrade cam and want to know what to get before disassembling it. Guy before I got it didn't know what was inside.
Old 09-15-2013, 10:03 PM
vinniekq2's Avatar
how can you pick a cam without knowing compression ratio?
Old 09-15-2013, 10:21 PM
techinspector1's Avatar
Wiki Edits: 326
Hmmmmmmm......
Old 09-15-2013, 10:22 PM
Wiki Edits: 326
Post the Alpha-Numbers that are stamped on the block deck at the very front of the passenger side (maybe behind the alternator).
Old 09-15-2013, 10:35 PM
vinniekq2's Avatar
Sorry Richard,Ive been messing with ya a little today,,
besides,your quotes are becoming classics
Old 09-15-2013, 11:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ID SBC roller blocks
Old 09-16-2013, 02:05 PM
If its a 96 or newer it has a roller cam. If it's a 95 it has a flat tappet but will have the roller cam provisions. Those provisions may not be finished, partially finished such as drilled but not tapped, or are completely finished, or some mix there of.
If you pull a rocker cover and shine a light into the valley if it has a roller cam you will see the dog bones that tie pairs of lifters together preventing rotation of the lifter and the legs of the spider that hold the bones in place. If you don't see dog bones spider legs it's got flat tappets.
Bogie
Old 09-17-2013, 08:28 AM
Unless the 880 block was used by GM for building a 350HO crate engine, the 880 block should contain a roller cam, they all are roller lifter ready.
They 1st came out in 1995IIRC. The 1st 880 production use was for the 1996 truck/van/SUV Vortec 350 run.
peace
Hog
638 vs. the 880 block Kal81 Engine 3 04-26-2013 03:47 PM
Getting to around 396cid using 880 block Hogg Engine 29 03-28-2013 01:47 PM
880 Block Rebuild Ethan071891 Hotrodding Basics 2 12-11-2011 09:53 AM
Stroker SBC with 880 block? 04SilveradoMykk Engine 5 11-25-2009 04:00 PM
Opinion on block #880 roller Racin4pennies Engine 7 12-10-2008 04:13 PM
